IEC60204-1 Different Systems in Duct.
Good Morning,
I have a machine with multiple multi conductor cables, and the 2 or three air lines in the same duct. The Air lines are suitably identified from the cables.
This is 480 Volt system. This "common" duct runs alone the side of the machine. Is this allowable under EN60204? In the US, The NEC would not allow it under 300.8. Thank you for your help.
David
David
