Bending or Torsional Fatigue?
Hi All,
Kindly see attached for the fracture surface of mild steel material. I am not sure is this fracture bending or torsional fatigue? Does anyone have any insight?
Thanks.
Thanks.
RE: Bending or Torsional Fatigue?
Look closer at the fracture surface using an SEM.
Thanks for the sharing. I have attached one more photograph on the other side frature.
Thanks.
If compression or a lateral bending force is applied either to to long beams or beams with a section where one dimension is significantly larger than the other this will result in twisting. To the effect that torsion comes into play where nominally / seemingly only bending would apply.
Kind request to OP: Could you provide a sketch of the application, i. e. environment of the fractured item, position to support points, loading, operational characterisitics?
Thank you in advance...
Roland Heilmann
Lpz FRG
1. Metengr "...Send the failed piece to a metallurgical lab for proper analysis with a complete description of the service or anticipated service conditions. No WAG about that." ... is exceptionally wise advice. However include a drawing and loading/environment data [etc] if available.
2. For 'recreational use'... IE: initial estimation purposes... You might find following documents useful...
ASM http://www.asminternational.org has several handbooks that detail metallography for various alloy families. However the 'bible' is latest version of...
ASM HANDBOOK, VOLUME 09 - METALLOGRAPHY AND MICROSTRUCTURES
Also... available on-line at degraded image quality is the monumental work...
WRDC-TR-89-4060 [ADA219747] FAILURE ANALYSIS HANDBOOK
NOTE.
I am lucky to have an original print-copy, in-which the photos/images are very clear and highly informative [procured in early 1990s]. High quality versions are likely available through libraries or Wright Labs [Wright Patterson AFB].
3. RE your second photo with the pieces rejoined: it looks like a 'narrow [~1/4] width sliver of material' is missing. This might alter or muddy the failure analysis somewhat
4. BTW... some serious advice for failure investigators. Fracture faces are highly valuable and must be carefully protected from further damage! Field handling and examination of damaged parts requires basic training [how-to] and carefully-restrained enthusiasm to avoid basic mistakes that could compromise further evaluation.
NEVER put fracture faces back-together! 'Close' is OK for graphical purposes... however even slight contact can alter the metallurgical evidence by incidental smearing.
ALWAYS Ensure that fracture faces are protected from further environmental deterioration by methods/means that will NOT transfer to the fracture faces. This advice extends to even touching the fracture faces with fingers and exposing the pieces to a 'dirty/polluted/corrosive atmosphere'.
Professionally photograph [very high quality/definition] the damage of each fractured piece from every conceivable perspective in both macro and close-up modes... including within the larger assy. These photos should be taken under direction/guidance by an experienced investigatorAS SOON AS POSSIBLE after the failure. It is amazing/humbling what good quality field photos can reveal when 'questions, concerns and puzzles' arise during lab examinations, days/weeks later.
NOTE.
Mishap/field-failure photography is an important part of field work... this is a hard lesson learned [HLL] from many field failure [aircraft mishap] investigations. Most pro-photographers are good at their craft… but utterly incompetent when it comes to understanding WHAT-TO-PHOTOGRAPH for general and specific forensic evidence [VHLL]! Great photographers will defer to technical competence and guidance to ‘take this image, of this area, at this angle/distance, with this lighting, with this definition, etc’... while not comprehending ‘exactly why’… and results are usually satisfying. CAUTION: non-cooperative/egotistical photographers are worse than useless [VHLL]!
Regards, Wil Taylor
o Trust - But Verify!
SAE HS-788 SAE Manual on Design and Application of Leaf Springs
Regards, Wil Taylor
