What does it meaning " install square end of bearing against spacer"
Dear All
My drawing indicates the note " install square end of bearing against spacer", i am not
very have ideal about it, could somebody can in further explanation, tks.
RE: What does it meaning " install square end of bearing against spacer"
I'm guessing something like a needle bearing in a housing.
Like this, which has one end quite rounded.
https://static.grainger.com/rp/s/is/image/Grainger...$
The other end is likely much more square, like this -
http://cdn3.volusion.com/nfczr.pzckq/v/vspfiles/ph...
1 down, 19 to go
Ted
