Pipeline Hydrostatic Test Temperature Probe Location
How far from surface piping should buried temperature probes be installed to avoid temperature fluctuation due to ambient temperature change during a hydrotest. I'm trying to specify the location of temperature probes for a buried pipeline hydrostatic test. I've found several sources online that specify the the temperature probes should be buried .5Km from any surface piping. Several people in my company want to place the buried temperature probes within 200 ft of the launcher where the test equipment is located. The temperature probes I'm referring to are the ones that attach to the pipeline. I've also seen references that specify buried temperature probes not attached to pipeline.
RE: Pipeline Hydrostatic Test Temperature Probe Location
I can't see any benefit going much more than 10m of buried line myself. you're not going to get any significant heating effect beyond that and the water flow is zero.
Making it inside the fenceline of the facility makes sense to me.
For longer lines you need at least a mid point one at a suitable point ( road crossings etc) if you can.
I've recently been completing testing specs and though our company just specifies one buried either end of the test section and the mid-point, most of contractors are putting an additional probe on the line due to the low ground temps and wanting to use water only rather than dealing with methanol. The key is how long the test section is. I agree with little inch that 10m should be plenty. I'm not sure what significant benefit you get from probes not attached to the line other than a reference ground temp.
