Best selection of ISO to put in title block
Can I get some recommendation for ISO standards that have to be mentioned in drawing title block. What is good to have,a nd what is must have?
_____________________________
Enjoy your work and have fun!
RE: Best selection of ISO to put in title block
Once a portion of the ISO GPS system is invoked in a mechanical engineering product documentation, the
entire ISO GPS system is invoked, unless otherwise indicated on the documentation, e.g. by reference to a
relevant document.
So, essentially, specifying the entire group of standards is optional.
Nevertheless the following may be recommended:
ISO 1101 as fundamental standard.
ISO 14405 (with appropriate modifiers) to specify how you measure your sizes
ISO 8015 for fundamental principles
ISO 2768 (with appropriate modifiers) or alternative for general tolerances
Also don't forget:
View projection method
Dimensional units (if operating from US or Liberia)
Workpiece edges treatment
Surface texture
Which ISO standards are you capable of following?
JHG
May I ask how you do it please?
