density
density
dear team,
please help,how to calculate the density of sulphur,which is contain:
sulphur=595,6056 kmol = 19059,3792 kg
h2o = 1,6796 kmol = 30,5561 kg
ash = 0,0798 kmol = 5,7293 kg
fe = 0,0103 kmol = 0,5279 kg
nacl = 0,027 kmol = 1,5755 kg
RE: density
You have 0.2% impurities (99.8 S), so it can't be far off of pure sulfur.
RE: density
Sulfur density is rarely, if ever calculated. Use the available sulfur density tables. It is a complex material to say the least.
RE: density
RE: density
RE: density
Sulfur is a solid at those conditions, so your density will depend on the degree of crystallinity, and whether or not it is powdered,
It is a complex material, so you might contact your supplier,
RE: density
thread135-273381: Liquid/Molten Sulfur specific gravity may be useful.
RE: density
I believe the op has indicated 140 Deg C conditions, so solid sulfur is being considered,
if you examine the density tables, there is quite a range of densities dependent on a number of factors and considerably different from the liquid state.
RE: density
RE: density
