Flow through a perforated drum
Does anyone of a suggestion on how to estimate the flow of water through a perforated screen? I have a slowly rotating drum (1.2 rpm) 30" in diameter. I want to know how much water I can flow through it from the inside out. I will be pumping into it but it will drain by gravity flow. Any help would be appreciated.
Thanks!
Thanks!
RE: Flow through a perforated drum
Maybe this will point you in the right direction.
I hope this makes sense. Thanks for your time.
Huber makes these types of drum screens and may be able to assist.
http://www.huber-technology.com/products/screens-a...
