Magnetic properties of different steel grades
Hi everybody
Shall I ask where can I see how the magnetic properties of steel change by changing the steel grade?
RE: Magnetic properties of different steel grades
Internet search engines such as Google, Bing and Yahoo can provide this type of resource for you.
There is no simple answer to your question. You are dealing with a half dozen variables or sothat are not specifically associated with the steel grade.
You can check a number of handbooks, ranging from Bozorth to more modern materials texts, and of course a large number of research papers.
304SS and to a lesser extent 316SS see an increase in magnetic susceptibility after cold work.
There's a good paper by Schenk on the subject.
It is not just cold working that will do that,
