Project Laser Measurement to Computer
I need to project Laser Measurement to a Computer in Real time.
Thanks for any help you can provide!
- Laser must measure in feet / inches
- Laser must measure between 5' and 75'
- Need to project the Laser measurement display onto a computer
- The measurement must project in real time
RE: Project Laser Measurement to Computer
Leica also makes the Disto which has a bluetooth interface... you might look into this; I've not used one and it does store some of the data. I don't know how the bluetooth works.
From their website:
http://lasers.leica-geosystems.com/ca/disto/d2
Dik
We have the Leica Disto D8, the bluetooth only allows for a transfer of information to MS Excel as a table.
It does not allow for it to be viewed in real-time.
https://www.ryobitools.com/phoneworks/laser-distan...
Walt
That may very well be a viable option!
I had no idea that product existed.
I sent messages to sales at Disto and they inform me they cannot do what I need.
Their software allows for "room design" software and excel spreadsheet calcs.
Laser Distance Meter DLS-C15
Pasted from <https://www.pce-instruments.com/us/measuring-instr...;
We also offer a laser distance meter for fixed mounting for multiple applications in the industrial sector such as position testing, testing coil weight, etc. This laser distance meter transmits digital or analog readings to a PC or a PLC-System for further analysis or as the basis for controlling commands.
AR1000 Laser Distance Sensor
The Acuity laser distance sensor model AR1000 can measure 30 meters with an accuracy of 3 mm. Using a reflective target board, the sensor will measure distances up to 150 meters. Ideal for measuring fill levels and material height monitoring, the AR1000 sensor can hold up to very tough environments.
Pasted from <http://www.acuitylaser.com/products/item/ar1000-la...;
LUMOS Laser Distance Sensors measure with millimeter accuracy at 500 meter measuring Range
Pasted from <https://www.jenoptik.com/products/metrology/laser-...;
Walt
I will investigate the lasers listed!
I truly appreciate your help!
I will definitely look into it.
Dik
LUMOS - LDM51 Series &
Acuity - AR1000
I am waiting on contact with their Sales department.
I will post once a decision has been made.
(I will try to post a pic of it in use as well)
