Use of LDC (Load displacement convergence)
I have to compress a piece of metal and perform a load-springback curve with NX 10.
It's a non-linear solution, and I am using the SOL 601,106 static analysis.
within the strategy parameters I can choose for the ATS,LDC, TLA, etc..
The solution will solve with the ATS but my solution has to be independent of time.
When the max-displacement is reached, the compression has to stop and then the sheet metal has to show a sort of springback.
The LDC function will be a perfect incrementation scheme, but It won't work.
Can someone tell me wich strategy parameters has to be changed from there default setting to use the LDC scheme?
Thanks in advance!
Thanks in advance!
