Associated sketches
Associated sketches
Using NX10.
I have a very simple model with three features. The first is a simple extruded rectangle with an embedded sketch. The other two features are simple extruded shapes subtracted from the first. The subtracted excursions have nothing to do with each other, but for some reason the sketches are associated. When I change the sketch orientation of the first, the second sketch also changes. Any idea? Thanks.
RE: Associated sketches
Second sketch has a reference to first extrusion which has a reference to first sketch.
Ronald van den Broek
Senior Application Engineer
Winterthur Gas & Diesel Ltd
NX9 / TC10.1.2
Building new PLM environment from Scratch using NX11 / TC11
NX9 / TC10.1.2
Difficult to say without having a look at the part itself. Can you upload it?
NX9 / TC10.1.2
