Bottom end failures
Bottom end failures
How you all doing I am having a problem with an engine and will like someone's help. I have a bolt out of a Conrad that came loose from an engine and destroyed the bottom end I will add some pictures off the Bolt. Any ideas would be appreciated.
RE: Bottom end failures
Mike Halloran
Pembroke Pines, FL, USA
Need some close up's of the bolt but it looks to me as though the thread on the bolt as sheared or was tightened in cross threaded
