How do you change the scale of a projected view?
Please address subject question. Thank you!
Thank you,
Trent
NX 9.0.3.4
RE: How do you change the scale of a projected view?
Hi Trent,
It helps if you mention which NX version you are working with.
I can tell you easily for NX 10 (which is likely the same in NX 9 and a little different pre-NX 9):
- Right click the view border -> Settings -> General -> Scale drop down menu (Setting group)
If you want, you can also show the scale for a given view in the same dialog:
- Settings -> Label (Section group) -> Show view Scale (Scale group)
SMO (NX10)
