Subtract with Pattern Feature CAD
I wanted to subtract two pattern elements from my workpiece, but get an error report. (See image and uploaded file)
In the discussion forum i couldn't find any help.
Is there maybe an alternative way to do this kind of operation?
Can i get the finished workpiece in .prt format?
Sincerly Rick
Sincerly Rick
RE: Subtract with Pattern Feature CAD
NX11 will return warning messages , not error messages, that some of the tool bodies doesn't intersect the target when subtracting the instanced bodies.
This is information only.
This seems to me like a Pro/E type procedure, i think this is how Pro/E sometimes handles similar tasks.
In NX i would rather sweep the profile provided i get the correct shape.
( NX11 can sweep Solid volumes compared to sweeping "profiles" in earlier versions.)
An alternative would be to instance the profile/The sketch, say 3-4 copies along the guide and then build a "trough curves" body from these.
If that would produce a different shape has to be tested.
The method used in the uploaded part will produce a "facetted" and kind of heavy model. But depending on the use, fully acceptable.
Tomas
Tim Flater
NX Designer
NX 9.0.2.5 Win7 Enterprise x64 SP1
Intel Core i7 2.5GHz 16GB RAM
4GB NVIDIA Quadro K3100M
