SOL 200 Problem
SOL 200 Problem
SOL 200 Problem
Hello all,
running the script below, I'll get the user fatal messages:
*** USER FATAL MESSAGE 316 (IFPDRV)
ILLEGAL DATA ON BULK DATA ENTRY DRESP1
DRESP1 1 FRMASS FRMASS
DRESP1 2 COMPLI COMP
*** USER FATAL MESSAGE 307 (IFPDRV)
ILLEGAL NAME FOR BULK DATA ENTRY TOPVAR
Does anyone know, how to correctly implement TOPVAR and DRESP1 into the script?
Kind regards
Fite
TIME 3.15E7
SOL 200
CEND
TITLE= Opt
SUBTITLE = Opt
SPC = 1
DISPLACEMENT = ALL
STRESS = ALL
SUBCASE 1
TITLE = G
SUBTITLE = G
LOAD = 1
ANALYSIS = STATICS
DESGLB = 1
DESOBJ (MIN )=2
$ 1 2 3 4 5 6 7 8 9
BEGIN BULK
PARAM,POST,-1
PARAM, NASPRT, 1
PARAM, DESPCH, 1
$ Includes
INCLUDE '/home/philkir/pers/test/Resbd/Resonanzboden.fif' $ GRIDS and ELEMENTS
INCLUDE '/home/philkir/pers/test/Resbd/Resonanzboden_Prop.fif' $ PROPERTIES
INCLUDE '/home/philkir/pers/test/Resbd/mat.fif' $ MATERIALS
$ Gravity
GRAV 1 9810. -1. 0. 0. -1
$ Fix
SPC1 1 123456 1079 1135 1191 37 93 149
+ 205 261 317 373 429 485 541 596
+ 651
TOPVAR 1 PSOLID 0.4 1001
DRESP1 1 FRMASS
$ Mass_Constraint
DCONSTR 1 1 0.4
DRESP1 2 COMP
DOPTPRM DESMAX 40P2 0P1 1
ENDDATA
RE: SOL 200 Problem
The USER FATAL MESSAGES are indicating that your version of nastran does not recognize and support the entries.
For DRESP1, it is saying that the RTYPES: FRMASS and COMP are not recognized and supported.
In regards to TOPVAR, your version of nastran does not recognize TOPVAR as a bulk data entry.
What version of nastran are you using? NX or MSC Nastran? What version/year are you using?
If you are using NX Nastran, FRMASS, COMP and TOPVAR are not supported.
If you are using MSC Nastran, you might be using an outdated version. In that case, you should upgrade to a new version that does supported those entries.
Feel free to email me if you have another nastran sol 200 question. e: christian.aparicio.2000 @gmail.com
