What type of gasket spec to be use for wafle type ball valve - END Armaturen
What type of gasket should be use at the position marked in the picture here?
RE: What type of gasket spec to be use for wafle type ball valve - END Armaturen
Which only you know at this point.
Reaction to change doesn't stop it
There's definitely an o-ring in there to seal the removable part of the housing that permits removal of the ball/packing.
I am not expert on the subject, but I guess it depends on which conditions you are sealing against (fluid, temperature etc), service, materials (roughness, finishing etc). Googling the valve model did not help very much.
Cant see how the OP question can be answered with such vague problem description.
Edit: by the way, the parts that are supposed to be fitted on each side of the body seems to be attached with screws located on the bottom of the picture. I am wondering how come there is no screws or similar devices on the top as well to ensure the parts are properly fitted against the body with forces being distributed more homogeneously. Just a thought...maybe I am missing something, can someone help me understand?
