movement by a torque
I'm trying to make dynamic analysis of a drive, but I have problem with applying a torque. With torque applied nothing happends, nothing rotates. Analysis works fine with rotational velocity as a load, but I'm obviously recieveng wrong stresses. Could someone help my with applying a torque in my simulation? If necessary I can upload files.
RE: movement by a torque
I this case create a reference node on the axis, use a coupling to connect that node to your face and apply the torque at that node.
