mainten less then 1 kg/cm2 pressure during cold box deriming
Dear team,
please help, why we mainten less then 1 kg/cm2 pressure during cold box deriming of nitrogen plant and dew point -70 c at vent point.
RE: mainten less then 1 kg/cm2 pressure during cold box deriming
There may be other reasons why the unit pressure should be maintained low - there could be differential pressure limits on heat exchangers or other equipment, or it could be the case that pressurizing the unit above 1 barg could result in a violent moving-breaking of the ice/condensate plug inside piping or equipment, that could behave like a projectile and damage the equipment.
-70 degC dew point is probably the safe threshold value below which water content does not represent any problem in the process, based on the unit licensor experience. For various cryogenic processes and technologies, these threshold values for dew point vary between -40 and -80 degC.
Dejan IVANOVIC
Process Engineer, MSChE
