nonlinear static analysis in sap2000
Dear experts,
I am using sap2000 v18 in design steel according to aisc 360-10 and as code required for all load combinations we must perform second order analysis including p delta effect , and the problem coming here sap is taking very long time during analysis, I want to know if there is any parameter in nonlinear parameters option can changed in order to speed the analysis up ,
I am waiting for your help,
thanks in advance.
RE: nonlinear static analysis in sap2000
Depending on the selected no-linear algorithm, the steps count can be reduced, as well as the convergence tolerance can be set to a greater value.
Jason McKee
proud R&D Manager of
Cross Section Analysis & Design
Software for the structural design of cross sections
Moment Curvature Analysis
Interaction Diagrams
Reinforcement Design etc.
