Stainless Steel Welding without Back Purging
If I back weld a stainless steel joint butt joint with FCAW would I then need to grind, gouge and clean up the opposite side prior to welding? Or should back welding limit the oxidation and sugaring?
Thanks!
RE: Stainless Steel Welding without Back Purging
Absolutely you need to remove the heat tint/oxidation from back welding with no purge and prepare the opposite side of the weld prep for welding.
yes gouge & clean up up to sound metal.
stanly
