Which coating is better for steel for corrosive environment?
Hi all
I'd like to know if zinc or Tin is a better metal for coating of steel? And what should be the other pole of the electroplating?
And how is the cost of the process calculated?
RE: Which coating is better for steel for corrosive environment?
"Corrosive environment" covers a cavernous range of potential environments and temperatures.
Some alternatives:
SYSTEM 05: HOT DIPPED GALVANISING
BASE METAL -STEEL
CLEANING -TO SSPC-SP 1 AND SSPC-SP 10
HDG -TO ASTM A123, THICKNESS TO Z275
SYSTEM 12: THREE PART EPOXY COATING OVER HDG
BASE METAL -HDG STEEL
PRIMER -DEVOE DEVRAN 201 EPOXY
SUBCOAT -DEVOE 'BARRUST 235 - MULTIPURPOSE EPOXY COATING'
TOPCOAT -DEVOE 'DEVTHANE 379H - ALIPHATIC URETHANE GLOSS ENAMEL'
SYSTEM 24: TWO PART EPOXY COATING WITH ZINC RICH PRIMER AND TOPCOAT
BASE METAL -STEEL
PRIMER -DEVOE 'CATHACOAT 302HB - REINF INORGANIC ZINC PRIMER
You can use products that may be more common to your area.
Dik
You should talk to a local coating supplier, in particular, if you have a really corrosive environment. My experience with coating tekkies (and not paint salesmen) is that they are quite good.
Dik
