Reorder Standard Parameter in NX
is there any way to reorder all standard parameters (p*) in NX (10/11)? I have a part which have currently up to parameter-number of 9000! This is a result of some pattern-features and some changes to them for different versions. So I have e.g. no parameters within 1000 to 2000 and more like that. So I want to renumber all parameters beginning with a "p".
Do any one of you have a tool, e.g. VB for that? Or do we have a standard function?
Best regards
Michael
RE: Reorder Standard Parameter in NX
The following program renumbers all expressions that have names that contain "p-Numbers".
The program is provided as is and I take no responsibility for any issues that could be encountered :)
CODE --> .net
Imports NXOpen
Imports System
Imports System.Collections.Generic
'' Renumber the all system expressions in workpart that match the specified regular expression
Module rename_system_expressions
    Dim TS As Session
    Dim LW As ListingWindow
    Dim WP As Part
    Sub Main(ByVal args() As String)
        TS = Session.GetSession()
        WP = TS.Parts.Work
        LW = TS.ListingWindow
        Dim systemRegularExpression = "p[0-9]+"
        Dim pRegExp As Text.RegularExpressions.Regex = New Text.RegularExpressions.Regex(systemRegularExpression)
        Dim temporaryRegularExpression As String = "_temp_[0-9]+"
        Dim tmpRegExp As Text.RegularExpressions.Regex = New Text.RegularExpressions.Regex(temporaryRegularExpression)
        Dim undoMark As Session.UndoMarkId = TS.SetUndoMark(Session.MarkVisibility.Visible, "Renumber System Expressions")
        LW.Open()
        LW.WriteLine("Processing Expressions")
        Dim expDictionary As New SortedDictionary(Of String, Expression)
        Dim expArray As Expression() = WP.Expressions.ToArray
        '' find and give all matching expressions a temporary name
        For ii As Integer = 0 To expArray.Length - 1
            Dim exp As Expression = expArray(ii)
            If pRegExp.IsMatch(exp.Name) Then
                Dim matchExp As String = pRegExp.Match(exp.Name).ToString()
                Dim pNumber As Integer = Text.RegularExpressions.Regex.Match(matchExp, "\d+").ToString()
                Dim uniqueKey As String = pNumber.ToString.PadLeft(100, "0") + "-" + ii.ToString
                Try
                    WP.Expressions.SystemRename(exp, exp.Name + "_temp_" + ii.ToString)
                    expDictionary.Add(uniqueKey, exp)
                Catch ex As Exception
                    LW.WriteLine("Failed to rename " + exp.Name + " due to " + ex.Message)
                End Try
            End If
        Next
        '' Renumber the found expressions
        Dim newNameCounter As Integer = 0
        For Each pair As KeyValuePair(Of String, Expression) In expDictionary
            Dim newName As String = "p" + newNameCounter.ToString
            Dim oldName As String = tmpRegExp.Replace(pair.Value.Name, "")
            Try
                WP.Expressions.SystemRename(pair.Value, newName)
                LW.WriteLine("Renamed " + oldName + " to " + newName)
                newNameCounter += 1
                LW.WriteLine("Failed to rename " + oldName + " with " + newName + " due to :" + ex.Message)
            End Try
        Next
        TS.UpdateManager.DoUpdate(undoMark)
    End Sub
End Module
Thank you! That works fine! Is it possible to modify it in that way, that if there are some parameters like "pattern_p*", that these parameters will get also the prefix "pattern_" after renaming?
Best regards
Michael
Sure This should work
CODE --> VB.net
Imports NXOpen
Imports System
'' Renumber all system expressions in workpart that match the specified regular expression
    Dim TS As Session
    Dim WP As Part
        WP = TS.Parts.Work
	Dim keepTextRegularExpression As String = "pattern_"
	Dim keepRegExp As Text.RegularExpressions.Regex = New Text.RegularExpressions.Regex(keepTextRegularExpression)
        LW.Open()
                Try
                End Try
            End If
        Next
	    If keepRegExp.IsMatch(oldName) then
	        newName = keepTextRegularExpression + newName
	    End If
            Try
                newNameCounter += 1
            End Try
        Next
    End Sub
End Module
