2 things to be improved in Draftsight
Good afternoon. Don't know if this arrives to Draftsight Team, but I think so.
1 - First thing is the "send to back" feature: with a couple of thousand objects select, it freezes because it takes to long to calculate the thing.
2 - The other thing is with "Smart select". If you are in a specific layer, select a bunch of objects and use the Smart Select, Select Property Layer, it show our Active Layer as the "equal to" parameter, but if you press OK it selects nothing. You have to selects things in a different Layer besides active.
Thank you for this wonderful software!
