Pier Leg Internal Forces
When using the Design Module for Etabs, is there any way to obtain the design shear force (Vu) for each of the legs of the piers?
I know you can view them in the design report for each pier, but it would be helpful for me to be able to export them in table format.
RE: Pier Leg Internal Forces
Try the display-> show tables command.
Jason McKee
proud R&D Manager of
Cross Section Analysis & Design
Software for the structural design of cross sections
Moment Curvature Analysis
Interaction Diagrams
Reinforcement Design etc.
Would be nice if you could also show these values visually.
This can be accomplished with the button Frame/Pier/Spandrel forces.
Jason McKee
Yes, but you would need to define each leg as a unique pier, rather than defining the whole core a single pier.
