Mercaptans removal
Mercaptans removal
Does any one know if there are any technologies that have higher selectivity for mercaptans removal over H2S? For example, in the natural gas containing both H2S and mercaptans, I prefer to remove mercaptans first, then remove H2S later. But so far, I could not find a technology with no or minimum coabsorption of H2S. Thanks for sharing.
RE: Mercaptans removal
Your idea may eventually work, if just a little of H2S is captured by AC, it should be acceptable. Did you have any practical operating experience of capturing mercaptans with min. coadsorption of H2S?
May we know why you wish to remove RSH, and then only H2S ?
I could only partially share some reasons. We are evaluating a technology for H2S removal; however, with high RSH, the equipment cost would be higher. If there is a technology could help reduce the RSH to lower level, overall,it might help to save the total cost.
Presume you're not considering MEA due to corrosion / degradation concerns.
Other options may be to optimise the column operation by using options such as intercooling, increasing circulation rate, but these would lead to higher cost as you say.
Obviously, if you could chill or cool this gas somewhat before the absorber, that will help to knock out the heavier RSH components and the heavy hydrocarbons too, and reduce the heavy HC co absorption associated with sulfolane.
Obviously, a split feed of lean solvent to the absorber may be another option to investigate with any of the solvent options mentioned.
Thanks. Sulfinol-X should remove H2S first; then RSH. We want the other way around.
