EN 13445-3, 17: Simplified fatigue assesment
In EN 13445-3: 2014 tables 17-2 and 17.3 are missing. I think this is an editing erratum. I will continue to use the tables of EN 13445-3: 2009.
RE: EN 13445-3, 17: Simplified fatigue assesment
True at least in the spanish version. I think they should be the same,
So where in EN 13445-3:2014 are Tables 17-2 and 17.3 referenced???
I am referring to the Spanish version:
- 17.6.2.3, second paragraph, mentions Table 17-3.
- Table 17-2, it is certainly not mentioned, and although the factors C1 and C2 are no longer necessary, but the values Δσ and Δσcut are still necessary to use the formulas of 17.6.6.
In addition, in 17.6.6.2 there is an erratum that persists since the 2009 version. It says: Δσcut <= Δσ* > Δσ
It should read: Δσcut <= Δσ* <= Δσ
