Calculation of condenser performance
Hi everyone,
Does anyone has an example of a calculation of condenser performance? I am following the HEI 10th edition... I've calculated the design conditions according to the datasheet of the condenser and the thermalkit...
But for real conditions...what should i use?
thanks.
thanks.
RE: Calculation of condenser performance
I have a spread sheet that I use for this.
You also will want to play with the fouling factor, this is the big one.
Ed
You need to use a little creative judgement for selecting min/max conditions.
You need for them to be realistic, but still to show the extremes.
