30mm blanks
30mm blanks
30mm blanks
I have a control panel with the 30mm holes with the notch. Pilot switches/lights. I need a blank to fill in a spot where there is no switch. My google searches are coming up with blank plates with a hole in it for labeling...
And suggestions?
RE: 30mm blanks
Try searching "enclosure hole seal or hole plug."
xnuke
"Live and act within the limit of your knowledge and keep expanding it to the limit of your life." Ayn Rand, Atlas Shrugged.
Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of Eng-Tips.
RE: 30mm blanks
I'm looking for something bigger on the outside, flat, with a seal threaded which screws on from the inside. I've seen them before, but can't find them. I looked at both posts and I didn't see a method of attachment...
RE: 30mm blanks
Thank you! A closing button. That's an obvious name for a panel blank or a hole plug. Thank you again!
