Daft Question About Parameters
Hello!
Once I've made a parameter and re-named it, is there any way of viewing the parameter type, or editing the parameter type?
Thanks all
Simon
Thanks all
Simon
RE: Daft Question About Parameters
Thanks for your help
You can't change the parameter type after creation. It's set in stone. Your best approach would be to create the new parameter of the correct type and use the "Replace" command to swap it in for the previous parameter and have all of the links update.
Drew Mumaw
www.textsketcher.com
www.drewmumaw.com
