Broken view problem NX9
I have a long cylindrical object shown using a Broken view.
Whenever I update the view the center line automatically disappears.
I tried with both 2D and 3D centerlines still am facing the same issue.
RE: Broken view problem NX9
you might try putting in separate smaller c'lines in each broken view - any edits to extend them together will probably revert to original lengths when you update, tho. But, it may work for you.
g.
gbangs
TC 8.3.3
NX 8.5.3.3 MP11
I called it in to GTAC expecting a PR, but it only ever made an ER.
NX 9.0.3.4
NX 11.0.1.11 (Testing)
Windows 7 (Windows 8.1 Tablet)
We noticed that sometimes also radial dimensions disappear. This is somehow connected to the ratio between the dimension and the view scale (GTac answer)
Ronald van den Broek
Senior Application Engineer
Winterthur Gas & Diesel Ltd
NX9 / TC10.1.2
Building new PLM environment from Scratch using NX11 / TC11
This issue is corrected in NX11.0.1
Didier Psaltopoulos
http://www.psi-cad.fr
