Regarding Maximum allowable stress & Design Stress Intensity
I have a query regarding Maximum allowable stress values , S , (From Table 1A) and Design stress intensity, Sm , (From Table 2A).
For A106 Gr B (-20 to 100)---- Design stress intensity= 20.0 Ksi
For A106 Gr B (-20 to 100)---- Maximum allowable stress values , S = 17.1 Ksi
My doubt is why this difference is coming?
I understand that 1A is based on : Maximum Principal stress Failure Theory
I understand that 2A is based on : Maximum Shear stress Failure Theory
Now as per Maximum Principal stress Failure Theory(Rankine Theory)---Plastic deformation occurs in a 3-Dimensional stress state whenever the Maximum Principal stress exceeds Syield.
And
As per Maximum Shear stress Failure Theory(Tresca Theory)---Plastic deformation occurs in a 3-Dimensional stress state whenever the Maximum Shear stress exceeds Syield/2.
But how we can find the clue about difference in Design stress intensity & Maximum allowable stress values?
Kindly share your opinion.
And
RE: Regarding Maximum allowable stress & Design Stress Intensity
The issue that you present has some merit as a controversy in VIII-2, because the fundamental formula for calculating wall thickness is based on maximum principal stress, yet combined loading is based on von Mises.
