Read .fil file. Problem during linking
Help, please!
I have the following issue:
I request a .fil (Job-2.fil) from abaqus through
* NODE FILE
U
Then I compile and link my ABQMAIN subroutine on Abaqus command. However when linking, the following error shows up:
The program I'm using is the following:
What can I do to fix this issue??
* NODE FILE
U
CODE --> Fortran
subroutine ABQMAIN
include 'ABA_PARAM.INC'
C
character*80 FNAME
real*8 ARRAY(513)
integer JRRAY(NPRECD,513),LRUNIT(2,1)
equivalence(ARRAY(1),JRRAY(1,1))
real*8 results(12136,12)
integer nn,ii,KEY
C
C File initialization
C Inicializacion de variables
nn = 0
results = 0.d0
C
FNAME='Job-2'
NRU=1
LRUNIT(1,1)=8
LRUNIT(2,1)=2
LOUTF=0
CALL INITPF(FNAME,NRU,LRUNIT,LOUTF)
JUNIT=8
CALL DBRNU(JUNIT)
C
C Loop on all records in results file
C
DO 100 K1=1,99999
CALL DBFILE(0,ARRAY,JRCD)
if(JRCD.NE.0)GO TO 110
KEY=JRRAY(1,2)
C
if (KEY.EQ.101) then
nn=nn+1
results(nn,1) = JRRAY(1,3)
results(nn,2) = JRRAY(1,4)
results(nn,3) = JRRAY(1,5)
endif
C
100 CONTINUE
110 CONTINUE
C
C
return
end What can I do to fix this issue??
