NR13 Pressure Vessel Code
I have a question relating to the NR13 document in my hands which states under 13.2.1 that pressure vessels whose PV product is greater than 8, where P is the maximum operating pressure in kPa and V is in internal volume in m3. Further into the NR13 document, the document states that pressure vessels are classified in potential risk groups in terms of PV, where P is the maximum operating pressure in MPa and V is the volume in m3. My question for those of you whom have complied to NR13, is 13.2.1 discrepant and should actually read in MPa? OR are they meant to be two separate calculations?
RE: NR13 Pressure Vessel Code
http://www.braziliannr.com/brazilian-regulatory-st...
Yes, two separate calculations:
1st: If NR-13 shall be applied to your vessel.
Item 13.2.1 b) P (kPa) x V (m³), if this product is greater than 8 (kPa.m³), so NR-13 shall be applied
2nd: What is the potencial risk group of your vessel?
to classify the vessel you need found the product P(MPa) x V(m³) and locates in the groups stated under 13.5.1.2 C)
Resume: First PV with kPa to apply NR-13 (or not). Second PV with MPa to classify the vessel in the potencial risk group
(NR-13 could use 0,008 MPa.m³, but SI recommends changing the prefix)
I hope I've helped
