Lag bolts vs thru bolts
What experience/opinions do you have on Lag bolt vs Thru bolting heavy timbers? I have heard lag bolts is no-no, but recent reading seems to change my mind?
Thoughts?
Thoughts?
When was the last time you drove down the highway without seeing a commercial truck hauling goods?
Download nowINTELLIGENT WORK FORUMS
RE: Lag bolts vs thru bolts
I'm thinking of using split ring connectors in addition to the steel reinforcements it has.
file:///C:/Users/DTimberlake/Downloads/Item-S-3b.pdf
The lag bolts have a double pilot hole requirement, if I recall correctly from NDS, that is fairly often overlooked by 'get-er-done' carpenters. check NDS.
