Hello friends welder stamp/ID mark
Hello friends
welder stamp/ID mark on pressure vessel shold be minimum 5/16" with low stress stamp/
please confirm.
stanly
please confirm.
stanly
RE: Hello friends welder stamp/ID mark
Stamped or electrochemically etched letters and figures
shall be in characters not less than 5/i 6 in. (8 mm)
high.
uht-86- Any steel stamping shall be done with "low stress"
stamps as commercially available.
regards
stanly
How many times do we need to answer the question?
1. You can use low stress stamp.
2. You can use a weld map.
General Blr. CA,USA
Are you building a vessel using UHT materials? If not, then of course this section is not applicable. However, it is a good idea to use low stress stamps regardless....mandatory for NACE compliant vessels.
You might want to look into using weld maps.
weld map is also necessary which shows what welding process and also welder i.d.
regards
stanly
