NX9 - Journal to import to CSYS (wherever it is placed)
When I record a journal to import a part file, it will only bring the file in at the same point it did when I recorded it. Even though I recorded it to come in to the csys. Can someone help me with how to import a part file so it comes to zero zero of the csys in modeling no matter where the csys is placed?
RE: NX9 - Journal to import to CSYS (wherever it is placed)
Here is the code I recorded...
Option Strict Off
Imports System
Imports NXOpen
Module NXJournal
Sub Main (ByVal args() As String)
Dim theSession As Session = Session.GetSession()
Dim workPart As Part = theSession.Parts.Work
Dim displayPart As Part = theSession.Parts.Display
' Menu: File->Import->Part...
Dim markId1 As Session.UndoMarkId
markId1 = theSession.SetUndoMark(Session.MarkVisibility.Visible, "Import Part")
Dim partImporter1 As PartImporter
partImporter1 = workPart.ImportManager.CreatePartImporter()
partImporter1.FileName = "R:\hms_tools\NX9\Tooling\part\ZERO DOWEL\ZERO_DOWEL.prt"
partImporter1.Scale = 1.0
partImporter1.CreateNamedGroup = False
partImporter1.ImportViews = False
partImporter1.ImportCamObjects = False
partImporter1.LayerOption = PartImporter.LayerOptionType.Work
partImporter1.DestinationCoordinateSystemSpecification = PartImporter.DestinationCoordinateSystemSpecificationType.Work
Dim element1 As Matrix3x3
element1.Xx = 1.0
element1.Xy = 0.0
element1.Xz = 0.0
element1.Yx = 0.0
element1.Yy = 1.0
element1.Yz = 0.0
element1.Zx = 0.0
element1.Zy = 0.0
element1.Zz = 1.0
Dim nXMatrix1 As NXMatrix
nXMatrix1 = workPart.NXMatrices.Create(element1)
partImporter1.DestinationCoordinateSystem = nXMatrix1
Dim destinationPoint1 As Point3d = New Point3d(0.0, 0.0, 0.0)
partImporter1.DestinationPoint = destinationPoint1
Dim markId2 As Session.UndoMarkId
markId2 = theSession.SetUndoMark(Session.MarkVisibility.Invisible, "Import Part Commit")
Dim nXObject1 As NXObject
nXObject1 = partImporter1.Commit()
theSession.DeleteUndoMark(markId2, Nothing)
partImporter1.Destroy()
' Menu: Tools->Journal->Stop Recording
End Sub
End Module
Option Strict Off
Imports System
Imports NXOpen
Module NXJournal
element1.Xx = 1.0
element1.Xy = 0.0
element1.Xz = 0.0
element1.Yx = 0.0
element1.Yy = 1.0
element1.Yz = 0.0
element1.Zx = 0.0
element1.Zy = 0.0
element1.Zz = 1.0
Dim destinationPoint1 As Point3d = workPart.WCS.Origin
End Sub
End Module
Change this code:
CODE
to this:
CODE
After making this change, you can eliminate all of the (now useless) "element1" code.
www.nxjournaling.com
This seems to have done the trick. Thank you very much.
