Exact Curve error when updating views
Anybody run across this error in NX10? When updating views in drafting: "Exact Curve could not be created. This was caused while updating an object of type in part (XXXXXXX.prt)" I can't find a solution except to delete the view and re-create it. Very frustrating if the view has a lot of notes and dimensions. Is it a bug or something I am doing?
Product Designer: I-Deas/NX/Catia
Automotive Industry
RE: Exact Curve error when updating views
The silence is deafening. bigears
Automotive Industry
I've not seen this particular error (but then again, I'm still running NX 9). These types of errors are best handled by contacting GTAC; they have better means of diagnosing the problem.
That said, I have seen similar errors in drafting, usually when updating a section view, that was caused by model geometry errors. Try running "examine geometry" on your model to see if anything comes up.
www.nxjournaling.com
