Abaqus: Error in shell-to-solid coupling analysis
Dear all,
I'm doing analysis where I use the shell-to-solid coupling method. In some jobs Abaqus works without problems and delivers good results, but in others it stops and delivers the following error message:
"Error in job: ALL ELEMENTS IN THE ERROR RECOVERY DOMAIN WHOLE MODEL MUST HAVE SAME NUMBER OF MATERIAL POINTS, LAYERS, DIMENSIONALITY, THICKNESS, AND ORDER.PLEASE SPLIT THE DOMAIN TO HAVE ONLY ONE TYPE OF ELEMENT IN EACH DOMAIN.
Job ShellToSolidCoupling: Analysis Input File Processor aborted due to errors.
Error in job ShellToSolidCoupling: Analysis Input File Processor exited with an error.
Job PruebaPresionestructura aborted due to error."
When Abaqus has found the error mentioned, I have partitioned the domains to have within each of them elements with similar characteristics. Even so, Abaqus detects the same error.
Some of you have some idea of what other reason can cause Abaqus to detect this error in the wrong way.
I will appreciate your help,
GEspinosa.
