what is output bias in control valve positioner ?
after installing a new control valve positioner (fisher DVC6200) & while making auto travelling
it stopped at stage "adjusting output bias" and didn't continue auto travelling .
-what is meant by "output bias" & why it stopped ??
RE: what is output bias in control valve positioner ?
If output refers to the positioner's pneumatic output, it could be a pressure offset needed to move off the zero % point (?).
The auto-travel section of the manual (below) lists some other errors that might warrant looking at for things to check, because I'm guessing that the auto-travel calibration did not complete because of this output bias error?
is anything moving at all during the test?
Linkage alignment issue?
inadequate air supply?
TTFN (ta ta for now)
Gunnar Englund
www.gke.org
