Help with expressions
Hello, i have expressions (string) with value "XX-EXX" or "XXX-EXX" or "XXEXX".
How to extract text "EXX" from differently expressions values?
Thanks.
NX 9.0.3.3
RE: Help with expressions
So you only want the "E" and everything following it? Does an "E" only appear once in the string?
If the answer to both questions is "yes", then one solution would be to use the "splitstring" expression function.
CODE
[string expression] test1 = "XX-EXX"
[list expression] splittest = splitstring(test1, "E")
[string expression] result = "E" + last(splittest)
If the answer to one of the questions was "no", a solution may be possible with a journal (a journal language would give you more string processing power and logic control).
www.nxjournaling.com
Yes, E and everything following. E is once in the string.
Thank You, it works perfectly.
NX 9.0.3.3
