Significance of Normalizing Before Q&T for 300M VAR
Hi all,
Designing some parts out of 300M VAR per AMS6417 and heat treating per AMS2759/2. I have some general metallurgy questions regarding normalizing and it's effect on the material's response to heat treating.
The raw stock is sent to us in the hot rolled normalized and tempered condition. Why would the mill temper after normalizing? Why not just normalize? I interpret AMS2759/2 to say that normalized stock must be preheated before hardening while AMS6417 makes no mention of that distinction. It just says to normalize and harden.
So my question is how/why does tempering after normalizing affect the outcome. Not a metallurgist but I am really curious about this. Seems like a redundant step as when you Q&T you're overwriting the previous microstructure with austenite anyway so it doesn't matter what it looked like before. Am I missing something here?
Any insight will be greatly appreciated!
Cheers.
Cheers.
RE: Significance of Normalizing Before Q&T for 300M VAR
I would hope that they used 1200F for the temper.
Many people will re-normalize, cool, then heat to austenitizing temp and oil quench, then double temper with air cool between.
On reason to N again is to assure uniform properties. We don't know what was done to it since you got it, how much stock was removed, or any cold work done. This is the safe path.
Maui
300M per AMS6417... Are You using bars, hand-forged blocks or forging stock? In each case there is a specific condition it MUST be delivered in. Typical for thicker bars is as follow from AMS6417...
3.3.1.2 Bars Over 0.500 Inch (12.70 mm) in Nominal Diameter or Least Distance Between Parallel Sides
Hot finished, annealed, or normalized and tempered having hardness not higher than 311 HB, or equivalent
NOTE. Your contracting needs to be very explicit regarding HOW the raw stock should be processed for delivery... or at least make it crystal clear what you have during receiving evaluation!
NOTE. 300M at 311HB is relatively easy to machine a to a 'rough state', before final ['hard-as-the-hubs-of-h*ll'] HT to 270--290-KSI or 280-305-KSI [AMS2759/2]. In these UHS HT states, machining/grinding carefully with a lot of coolant and sharp tools is mandatory [see para 3].
However actual final heat treat process will depend on the state of the material, before Solution HT, this...
2. AMS2759/2...
TABLE 2A - ANNEALING, NORMALIZING, AND AUSTENITIZING TEMPERATURES AND QUENCHANTS, INCH/POUND UNITS
(2) All parts, except those made from H-11, 52100, or M-50 steels, shall be in one of the following conditions prior to
austenitizing: normalized, normalized and tempered, normalized and overaged, or hardened. If such parts have
been normalized only, without tempering or overaging, they shall be preheated within the range of 850 to 1250 °F
before exposure to the austenitizing temperature.
3. I found the following SAE document gives a very clear/stark discussion of processing 4340M and 300M into finished parts.
ARP1631 Manufacturing Sequence for Fabrication of High-Strength Steel Parts 300M or 4340 Modified Low-Alloy Steels 270,000 psi (1860 MPa) Tensile Strength and Higher
Processed correctly, 300M will serve capably and predictably at UH strength. However the process is EVERTHING: miss something, get something wrong, or miss-sequence the process and there could be 'hell-to-pay'.
Also I suggest serializing every part with a PERMANENT number so that it has INDIVIDUAL processing records. If something is amiss during a records review or interim/final QA eval, then at least You know which part(s) is(are) affected! This happened with one of my vendors: They failed to trace parts by explicit SN... and one set of records showed a process 'aw-sh*t' for [3] major parts after one HT operation. We had a hard time with the MRB disposition for these $150,000 parts!
Regards, Wil Taylor
o Trust - But Verify!
Just thought I'd give you some details on the actual part the material is for. It's a piston to be machined from 3-1/2'' bar stock. It's going to be loaded in pure compression (some areas in tension, like the port hole) around 100x with a lot of the loadings right on the edge of yield. Looking to do whatever it takes to maximize the strength. 300M seems like a good candidate. Other choice would be a 300 maraging steel.
WKTaylor,
Thanks for the heads up on ARP1631. The document does a great job of specifying the required processing sequence. I'll be sure to have a thorough discussion with our heat treater and machine shop about it. I'm out west and deal mainly with oil field shops so it may be difficult to get them on the same page regarding the strict adherence to the AMS standards.
Question for all. What would you say is easier to process/achieve? Max strength with 300M or a 300 maraging steel? I'm starting to lean towards the 300 maraging steel because it seems like less can wrong in the processing sequence. And it might even end up being cheaper. Thoughts?
Thanks in advance for all the input!
If you are worried about 300M perhaps AirMet?
Be extremely cautious using 300M for engine parts! Due to extremely low tempering-temperature [550--600F], it does NOT tolerate high heat very well without changing the mechanical properties... dramatically. Above 600F, the 'blue-brittle' [temper embrittlement] phenomena can occur. In aerospace, 300M is considered a structural alloy... IE: highly stressed landing gear components and fitting attachments... that rarely see temperatures above 250F.
IF used in engines, You probably should consider 9Ni-4Co-0.20C or -0.30C [RT 220--240-KSI]. Per MMPDS-10, both alloys perform well-up-to ~900F.
For instance... these alloys [with nickel plating for corrosion protection] perform well as turbine-engine hot-section [750F] engine mounts and drag/thrust/sway-links.
2.4.2 9NI-4CO-0.20C
2.4.2.0 Comments and Properties — The 9Ni-4Co-0.20C alloy was developed specifically
to have excellent fracture toughness, excellent weldability, and high hardenability when heat-treated to 190
to 210 ksi ultimate tensile strength. The alloy can be readily welded in the heat-treated condition with preand
post-heat usually not required. The alloy is through hardening in section sizes up to at least 8 inches
thick. The alloy may be exposed to temperatures up to 900EF (approximately 100EF below typical tempering
temperature) without microstructural changes, which degrade room temperature strength.
2.4.3 9Ni-4Co-0.30C
2.4.3.0 Comments and Properties — The 9Ni-4Co-0.30C alloy was developed specifically
to have high hardenability and good fracture toughness when heat treated to 220 to 240 ksi ultimate tensile
strength. The alloy is through hardening in section sizes up to 4 inches thick. The alloy may be exposed to
temperatures up to 900EF (approximately 100EF below typical tempering temperature) without
microstructural changes which degrade room temperature strength. This grade must be formed and welded
in the annealed condition. Preheat and post-heat of the weldment is required. The steel is produced by
consumable electrode vacuum melting.
Regards, Wil Taylor
Appreciate the concern. It's not for an engine. Going in a down hole environment where it'll see max 400F. I would never make the mistake of unintentionally tempering during use...at least not yet haha :)
Gonna go with 300M and see what happens. Appreciate the comments all.
Cheers.
http://www.questek.com/ferrium-m54.html
Regards, Wil Taylor
Wow. I will definitely keep M54 in mind for future applications. The mechanical's are insane. Thanks.
WKTaylor,
We feel okay about 300M for the well bore environment despite the risk of SCC and hydrogen embrittlement from H2S. We have lots of parts made out of 4330V (lower quality air melt not the primo VAR) nitrided and they have stood up great. Will make a few prototypes and see how they perform before we splurg on any protective surface treatments. Likely go with electroless nickle plating if we do indeed need it.
Other Ferrium alloys...
https://www.cartech.com/en/product-solutions/
search 'Ferrium TDS'
Ferrium S53 has high mechanical strength/durability... and significantly improved corrosion resistance!
Regards, Wil Taylor
A couple comments in addition to the excellent advice provided by others.
If strength is a major concern, you might consider using AMS 6419 which should provide slightly better strength than AMS 6417. The two alloys have similar composition except for a slight difference in C content.
As WKTaylor noted, careful processing of parts made from this material is critical to ensure the finished product will perform as expected. For example, simply stating "heat treat per AMS2759/2" is probably not sufficient. The 3-1/2" diameter AMS 6417 raw material specified is hot rolled, and to obtain best results from heat treat a minimum amount of stock should be removed from all hot worked surfaces prior to heat treat. AS1182 provides guidance for stock removal allowance on premium aircraft quality steel bars. You also need to provide guidance to your heat treat vendor regarding part classification per AMS 2759/2 section 3.3.1. Based on your description, the part should be processed as type 1. This means at least .020" material will be removed from all part surfaces after heat treat.
NOTE.
300M has one unique capability: very deep/thick section hardenability.
REF MMPDS-10...
Table 2.3.0.2. Maximum Round Diameters for Low-Alloy Steel Bars (Through Hardening to at Least 90 Percent Martensite at Center)
Maximum Diameter of Round or Equivalent Round, in
300M and D6AC [be careful with this alloy] are the only 'conventional' LA steels that can be quenched/tempered in section thicknesses up-to 5.0-Dia Round/Equivalent-round... see Figure 2.3.0.2
NOTE.
Allowable [recommended] LA steel section thickness for successful Q/T are in some cases shockingly low for many conventional steels.
Figure 2.3.0.2. Correlation between significant dimensions of common shapes
other than round and the diameters of round bars.
NOTE.
I personally wouldn't recommend relying on Q/T above 4.50"-section thickness, unless You have a REALLY savvy heat-treater, and/or You are boring-out the middle on the material. Even then, I would recommend metallurgical testing of fully tempered/machined parts to verify 'everything' [grain quality, grain-flow, mechanicals, toughness, etc...]
Also... 300M [and most VHS/UHS steels] can be very 'disagreeable' when it comes to forging parting-planes and the resulting grain-flow disruption.
Regards, Wil Taylor
If you need to test something that would be on my list.
Thank you. Yeah we looked at the slightly higher carbon version of 300M but it was a bit of a pain to procure so we settled with the regular version. Any negatives to the higher carbon version? Reduced fracture toughness due to increased carbon?
WKTaylor,
I agree that attempting to through harden 4.50'' sections would be pretty crazy!
EdStainless,
We've currently specified longitudinal tensile testing of three equivalent rounds (diameter = 2x max section thickness) that will accompany the lot of parts during heat treat. Will have a discussion with the boss about potentially amending.
With respect to controlling surface decarb from the mill we will be rough machining off at least .125''. Max thickness of part to be approx .565'' so confident in achieving good through hardening. We've also decided to re-classify the part as "Type 3: Parts with finished machined surfaces or surfaces with less than 0.020 inch (0.51 mm) to be machined off any surface after heat treatment and parts with protective coating on all surfaces." So rough machining will take care of the surface decarb from the mill and the final machining will clean up any critical surfaces for final assembly.
This is my first foray into the world of ultra high strength parts so I really don't want to mess anything up. You've all been incredibly helpful and I really appreciate it.
Currently debating the cost/benefit of doing a final stress relief after final machining. Will be taking off ~.005'' for critical seal surfaces around the gland and rod body. The piston is loaded in pure axial compression at low speeds (treating as static). My reasoning for stress reliving is to eliminate the residual surface tensile stresses induced by final machining. We won't be shot peening (I don't like) so I feel like the potential for a low cycle fatigue crack failure is high. Is the concern warranted? Any thoughts?
300M requires two identical ['DOUBLE'] tempering cycles. This ensure 100% grain transformation.
Option 1. IF BOTH Tempering cycles are accomplished on the rough machined part in succession, then a stress relief operation [SRO] on the finish-machined-part is highly recommended.
NOTE. This sequence-scheme is simple and straight forward and hard to mess-up. Also the SRO can be delayed until just before application of plated finishes [can be done by the plater].
2. IF You can split tempering operations there is a nifty way to eliminate the SRO... although testing is advised to ensure no distortion.
Accomplish first temper operation of the rough machined part.
Finish machine the part.
Accomplish second temper operation of the finish machined part.
The second [mandatory] temper operation becomes the defacto SRO. In general the tempering operation HAS to be [should be] done by a certified heat treater. The part then gets routed to the plater who does not have to do a pre-plate SRO.
This routing can get messy and confused between sub-tier processors: ABSOLUTE process clarity and tracking are essential.
Regards, Wil Taylor
AMS 2759/2 type 3 processing only permits class A or B atmospheres, so decarb should not be a significant problem.
The residual compressive stress from shot peening is helpful for surfaces subject to tensile stress/load cycle conditions that can produce fractures. Based on the description of your piston service conditions above it does not sound like it would benefit from shot peening. In any case, you should never stress relieve a part after shot peening.
As WKTaylor noted above, AMS 2759/2 table 3 requires at least two tempering operations for 300M. His recommendation of finish machining after the first tempering cycle seems like a good idea. There is a requirement in AMS 2759/2 sec 3.4.8 stating "parts should be tempered within 2 hours of quenching" that you need to consider.
1. Tbuelna makes a very important point: 'rough machining' means 'machine to oversize, not to finished dimensions': and definitely DOES NOT MEAN to leave it with ragged/rough-edges and surfaces... which can be crack starters.
Generally speaking: IF You can run your bare fingers quickly all-over the parts and not get abrasions/cuts that's probably ‘good-enough surface-finish for rough machine parts’, at this stage. IF YOU get hurt doing this the surface is too rough to safely SHT.
2. Also, SHT/Q, followed by first temper operation is by-far the critical operation... to stabilize the part in approximately final temper state [W/~80--90% grain transformation completed]. I think-of the second temper operation simplistically as the 'completion-temper'... whatever grain/metallurgy transformation was not accomplished with the first temper operation is completed by the second operation [to reach ~100%]. And it is a stress-relieving operation also.
When the heat-treat, machining and plating processors are widely separated [sometimes hundreds of miles apart], I prefer that the heat treater do BOTH tempers steps to 'giterdone'... then have the part finish-machined[ground]... then have the plater do a true [post machining] pre-plate stress relief operation.
However, one prime vendor we had nearby [who did all machining operations] was just down the street from their heat-treat processor and had a great relationship with them... so doing the rough-machine/first-temper/finish-machine/second-temper process efficiently was common 'stuff' for them [our aerospace work was a 'small job' for them, compared with their on-going local AG/diesel-engine work].
NOTE. Heat-treaters are sometimes called-upon to do interim re-annealing operations when lots of steel-cutting [in the low-temper state] is required... and surface hardening or distortion is noted.
3. CAUTION!! One of the hardest 'elements' that all the processors had was getting their ‘people’ [machinists/techs/transporters/etc] to recognize that on-going flash-rust and impact-damage prevention was serious business! These parts have-to-be-protected by corrosion preventatives and packaging from incidental corrosion and handling damage between operations [oil, CPC, VCIs, barrier papers, heavy duty impact-absorbing wood/cardboard/boxes/crates, etc].
4. NOTE, regarding shot peening...
Generally speaking, for steel and CRES parts HT ~200-KSI [depending] and above, special peening shot and processes are required.
Specify high Intensity peening levels and high hardness steel shot [cast or cut-wire].
Intensity will depend on localized material thicknesses and M&P or specification recommendations.
‘High hardness shot’ [cast or cut wire steel] should be per AMS2431/2 or /8 [and maybe /5], or equivalent. ‘Regular hardness shot’ will NOT actually peen very/ultra-high strength/hardness steel materials.
Also, I always recommend 200% [2.0] coverage, thus… peen it 100% [1.0] all-over-once… then peen it the same way, again!
NOTE.
Peening compresses the surface for fatigue improvements [to retard crack initiation]; and also ‘hardens’ the surface for improved impact and wear resistance.
Some generally useful peening specs & info…
AMS-S-13165 [cx, good info] Shot Peening of Metal Parts
AMS2430 Shot Peening, Automatic
AMS2431 Peening Media
SAE HS-84 Manual on Shot Peening
SAE J2441 Shot Peening
Curtis-Wright [Metal Improvement Co] https://cwst.com/about-us/technical-articles-produ...
NOTE: AMS2546 Laser Peening [W/O shot!] might also work… but unsure…
Regards, Wil Taylor
I like the idea of doing the finish machine in between the two tempers. Unfortunately I don't think the machine shop and heat treater can handle the hot potato process. The parts will be moving around the country too much and something would probably go wrong with us ultimately picking up the tab. But a great idea for sure. Something to shoot for on the next batch after we get all parties up to speed on the basics.
tbuelna,
You're right that shot peening wouldn't help me much for most of the piston since it's in compressive loading. But there are a couple areas on the piston that have tensile stresses. Specifically, a port hole and the shoulder between the rod and head. I've done my best to abide by best design practices with large radii and an undercut to minimize the force flow disturbance, but there will always be that bloody port hole. So I was thinking shot peening would help me out in these areas. I'll probably skip the peening since it's not practical to reach into the hole.
Thanks guys. I'll let you know how the finished parts end up performing!
Cheers.
If your port hole and shoulder have axisymmetric profiles, there are other techniques besides shot peening to produce a residual compressive stress in the surface to improve fatigue performance. There are some roller burnishing and fillet rolling tools that can be used with steel at Rc 52-53 hardness like that of your piston. Might be worth looking at if fatigue stress is a concern in those areas.
Just got our tensile test specimens back. Results are great:
Average of two test specimens:
Yield - 237ksi
Ultimate - 280ksi
Elongation - 11%
Reduction in Area - 36%
Hardness - 65 HRC
So high five to all of you for helping!
