Dimensions in Sketches
9
Hello. Just wanting to get some opinions on something I've run across recently.
When updating dimensions in a sketch, I change the dimension. I do this because I like a "clean" sketch. For example, if the dimension is .50 and I'm making it .25 longer, I change the dim to .75.
I recently was working on a sketch created by a coworker. In his sketch the dimension was .50+.25. When I asked him about this, he said that that was his way of keeping track of the changes he was making. At first, this went against my instinct of having an uncluttered, clean sketch, but the more I've thought about it, it might make sense to do it that way.
Am I letting my OCD get in the way of a good technique, or is it best to leave a clean sketch as my legacy to others?
Your thoughts please.
RE: Dimensions in Sketches
For me personally, I prefer "clean" numbers like what you describe. I would rather keep track of changes in other ways (dated prints/markups, new revisions, emails, etc) that give me a clearer image of why the dimension changed.
I'm still pretty green (coming up on 3 years out of college), so I'm interested to hear other responses as well.
I really don't think it matters. It's just a weeny more amount of bits stored in the file. Whatever floats your boat.
To reinforce your coworkers point, at least there is a record of the change somewhere in the history IF someone HAPPENS to leave it out of a revision block or something. Having both there would at least maybe trigger a conversation vs. glancing over it for minimal changes.
Felix K. Holloway - Molded Fiber Glass Companies
Doesn't bring any added value in my opinion. You only see the changed value. You still don't know why it has been done.
Ronald van den Broek
Senior Application Engineer
Winterthur Gas & Diesel Ltd
NX9 / TC10.1.2
Building new PLM environment from Scratch using NX11 / TC11
5
I often use this technique; I find it helpful early in the design stage when the design parameters are still being worked out and you feel that a certain change may need to be rolled back later. Of course it is most effective when the entire team at least knows of the technique, but there are ways to clue them in. When typing in an expression formula, you can add a comment by adding "//" to the formula; anything following the "//" will be kept as a comment. So when typing the formula, it may look like:
CODE
0.5 + 0.25 //added length for reasons
In the expression editor you will see "0.5 + 0.25" as the formula and "added length for reasons" in the comment column.
On a related note, you can add comments to features. In the part navigator, turn on the "comments" column. Then by selecting the feature and single clicking in the comment cell, NX will allow you to add some text. This can be useful if you are doing something that may seem strange to the next person working on the part or you just want to document why the feature is there.
www.nxjournaling.com
I've done this on occasion, usually if a sketch dimension represents the sum of several 'variables' derived from some other aspect of the design but not necessarily ones that could be directed linked. This way if any of these 'variables' change, it's easier to make the adjustment to the specific value in the sketch dimension/expression.
One thing to keep in mind which may help people look at how to leverage the unique capabilities that are available to you is to think of the dimensions as being part of the "design Intent" of your product. In this case, what I was doing was recording the "Design Intent" as a the SUM of several external parameters. Of course, if you were take this approach to it's logical conclusion, perhaps it would be better in situations like this by first creating an expression where you would capture these sets of 'variables' and then simply reference this secondary expression when creating your sketch, or for that matter, your feature parameter. Approaches like this can go a long way to capture your "Design Intent" not just for your own gratification, but for anyone who in the future may be expected to modify or update your models. Anything that can be done to leave behind an understanding of what and why something is what it is can prove to be very valuable.
John R. Baker, P.E. (ret)
EX-Product 'Evangelist'
Irvine, CA
Siemens PLM:
UG/NX Museum:
Thanks for the tips on commenting Cowski, I had no idea that was possible.
Great points John, thanks for reminding us about how expressions really would be the way to go if you were following the methodology you say. Update one, and all update accordingly. Good to see your posts again, the community just isn't the same without them.
Felix K. Holloway - Designer
Did I help you out? Add me on LinkedIn!
I'm using commented like Cowski
But this way
0.75//0.50
New value//old value
hey john, how come nx 11 can't dimension a diameter in a sketch?
also, happy retirement.
I don't know as I don't have a copy of NX.
As for my retirement, it is what it is.
Irvine, CA
Siemens PLM:
UG/NX Museum:
Hi John
How is it possible for you to live your retirement wihout a copy of NX ?
It should a gift from Siemens.
Didier Psaltopoulos
http://www.psi-cad.fr
When I retired last January (2016) I was not offered nor did I request a copy of NX (besides, there are NO Windows-based systems allowed in our house and I was never a fan of the way we implemented NX on the Mac).
Now I know it can be arranged since for several years I personally 'sponsored' (annually signed-off on) a free copy of NX for a 'retired' user who's still a frequent poster here on Eng-Tips.
However, I've had other things on my mind of late, which you can read about at:
http://www.eng-tips.com/viewthread.cfm?qid=419979
Now it hasn't all been as dark as it might sound, as I have been doing some 'restorations' between visits to the doctor and/or the hospital, as can be seen at:
http://www.eng-tips.com/viewthread.cfm?qid=408398
http://www.eng-tips.com/viewthread.cfm?qid=412462
http://www.eng-tips.com/viewthread.cfm?qid=415015
Note that I am recovering nicely and am about 1/4 of the way through a 12 week cardio-rehab regime (I go three days a week). I've even managed to lose a few pounds winky smile
Irvine, CA
Siemens PLM:
UG/NX Museum:
Hi John,
I did not read all your posts, I congratulate you for all your restoration work and wish you a good recovery
Didier Psaltopoulos
I do as @cowski does. It's useful to me and may be a 'tip' to someone checking up on my work to see if I accounted for something. If they see the dim is ".250 + .015 //finishing stock" they'll know I added a little extra material to be finished after assembly or something.
More importantly/frequently - it's me. I work in an environment where I'm /very/ frequently interrupted. It's me seeing if I did something. We all have our ways of keeping notes, and it adds nothing detrimental to the sketch. At least this wastes no extra paper. If you care about a sketch dim being a formula of values instead of a simple number, you care about silly things, imo. So yes, maybe it's a pseudo-OCD quirk.
It's no different than seeing someone's ridiculous amount of face-moves to add thickness, move a hole, etc. I find that abhorrent but it seems that people do that frequently. Makes the history look terrible, and is hard to keep track of. I prefer modifying the source data than using boolean operations or face-edit operations to adjust on the fly.
That may also be my own personal idiosyncrasy, though :)
randy64,
In case this wasn't mentioned, if you want to remove the math and only have the value shown, you can simply click the drop-down arrow, next to the formula, then select "Make Constant" at the bottom of the menu.
I usually like to clean things up too, prior to releasing parts - just to keep things clean and simple for downstream users to understand.
It's good practice to use this technique, if you want to track uncertain changes as that part is being developed, but not so much for leaving them behind for the next person to figure out (such as in your case now).
Not a huge deal, really, but just another time killer.
SMO (NX10)
does anyone else know (or john remembers) why can't NX dimension a diameter in a sketch?
or can it, but it's just slightly different to solidworks for example?
I'm using NX10 and diameter is the default dimension when it applies auto dimensions to a circle. When I use 'Rapid Dimension' and pick a circle, it also defaults to being a diameteric dim.
I'm in NX11 and dimension diameters all the time, not sure why you can't.
loki3000,
The dimensional tool in sketch for circles and arcs (radius and diameter) is combined into one function. "Radial Dimension".
Using this function on a circle, you just change the option to "Diametral" instead of "Radial".
Why have two functions when you can do it all with one?
Felix K. Holloway - Designer - NX 9 & 11
@loki3000
When I first started with NX, I was trying to dimension the centerline of a revolve feature for diameter, like in SolidWorks. Then I found out that you can't actual do that in NX, which baffled me because it is such a convenient feature. But I adapted by simply dividing the diameter value by 2. Still would prefer being able to dimension the centerline and hope it would be implemented in the future.
Hi Loki3000,
It's not easy like SolidWorks but I often use make symetric then cylindrical dimension to do the job
Didier Psaltopoulos
I do like Didier but I select the
entire profile and then convert
the mirrored profile to reference.
that way I see the feature shape.
I must be totally missing something. You can dimension any line pretty much any way you want in NX...
I revolve sketches about their reference axis all the time and it is a breeze. Maybe we are not on the same page.
Felix K. Holloway - Designer - NX 9 & 11 Native
here a flat screw revolve example (I see the shape of the screw)
Right, I don't see why you cannot dimension to the centerline instead above. screw shaft would be 1.25 and top corner of head would be 3.5. I'm confused why people think it's not possible or easy to do this.
Felix,
Because we're all different and will never agree that everything should be done one way every single time - that's why. Some people just prefer to see the entire profile in their sketch and work with the diametric values to avoid any possible confusion or mistakes that might happen during calculating the radial values. Others, like yourself, can function just fine by working with the radial profile only.
Pretty much the same non-issue that it has been since Sketcher was introduced.
Tim Flater
NX Designer
NX 9.0.2.5 Win7 Enterprise x64 SP1
Intel Core i7 2.5GHz 16GB RAM
4GB NVIDIA Quadro K3100M
As we always used to say, "With UG (NX), the GOOD news is that there are always 10 ways to do something. The BAD news is that nine of them are perfectly valid."
Irvine, CA
Siemens PLM:
UG/NX Museum:
The worst news is that the one invalid method won't rear its ugly head until late in the project cycle.
I prefer my solution because I display all dim as PMI, then it's a gain of time in drafting.
Didier Psaltopoulos
Revolved profiles arr generally simple
and rarely complex.
And its nice to see its final shape in th sketcher
Yes, repeating the same thing over and over and over - some do it one way, others do it another.
Tim Flater
NX Designer
Thanks for the replies all! Your totally right about individual preferences, just how it goes even under the same company roof.
Understanding that, what my confusion was alluding to was loki3000's statement that it cannot be done. When in reality it can, although the function is not the same in the comparison software (SW).
Great quote John, I will remember that one when I am tutoring the next employee we get on NX.
Felix,
I could be wrong, but I believe what other users are saying CANNOT be done in NX Sketcher is two fold:
1.) Dassault CATIA v5 & Solidworks Sketchers allow line(s) to be labelled specifically as an Axis, meaning that line is recognized as something more than a line in a sketch, which NX does NOT do - we only refer to that sort of line as an axis - it doesn't change any sketch behavior at all.
2.) NX Sketcher recognizing a true Axis and then allowing for diametral dimensioning without additional geometry. Using NX, we "work around" this "limitation" by mirroring the Sketch geometry and making it reference or using a point on the opposite side and THEN dimension between the curves - Dassault apparently doesn't require that from my understanding.
In all, whatever Dassault is doing in its sketchers, it is removing some steps from the process that NX users have to go through to achieve basically the same end result when diametral values are desired. I believe that is what users are saying cannot be done in that specific manner.
Hope that makes sense.
Tim Flater
NX Designer
Hi Tim, that is exactly the answer I was looking for, felt like I was grasping at thin air there for a bit. Thanks a lot for posting that! Great to know. I've never thought it as a hindrance and my mind just works the way NX does now so very interesting to hear comparisons from the other systems.
Also keep in mind what Didier points out in that dimensions inherited on drawings may need to have the diameters shown, which can be inherited from the NX Sketch. Another reason why some "can't" use radial sketch dimensioning.
Tim Flater
NX Designer
