Yielding of welds
Yielding of welds
I completed a calculation package a few weeks ago regarding the modification of some lifting lugs welded to a rigid frame. The weld strength calculated from the ultimate strength of the weld metal (70 ksi min.) is adequate for the load with a >5 FOS, but one of the comments I got back was "what is the weld's FOS on yielding?" The yielding of the joined materials has already been addressed elsewhere in the calcs, so my question is: do welds even yield? and if they do, how do I calculate that condition? I have yet to see it addressed in AISC or ASME BTH. Thanks in advance for your help.
RE: Yielding of welds
To me this question would only become a problem if you're welding material with a higher yield strength than the filler- but you (should) never be doing that. If the weld itself is stressed beyond yield but below UTS, the base material adjacent to the weld is stressed to the same level, and will already be in the yield zone.
The throat thickness can also be deeper than the simple geometric throat of the weld, and possibly thicker than the leg length, parts being joined, or both, if deep penetration fillets are used. See attached image for clarity.
If the thicknesses of the parts being joined and the weld are imagined as tubes, and stress flowing through them is imagined as water, the diameter of the weld 'tube' is the throat depth- NOT the leg length.
Another way to picture this is that if you were to slice the weld through its neutral axis, and then measure the cross section, you would be measuring weld length and throat depth.
Ultimately, it sounds like you already have a weld stress level from previous calculation. If you have this number, compare it to the weld metal yield stress at the specified weld size, and you have a safety factor for weld yielding.
Fillet welds normally act and fail in a shear (shear stress) mode, at the least weld failure area region, which is the throat of the fillet, irrespective of their exact loading orientation. You should pay some attention to the weld stress at the leg dimension too, particularly when you are welding to a lesser yield stress material. The yield stress in shear is approx. (Fy)/(3).5 = .58(Fy) for steel, where Fy is the yield stress in tension. And, your allowable weld stress is based on this shear yielding stress. Usually, you don’t have to worry about the shear stress at the leg failure area because the leg is longer than the throat and the filler metal and base metal are matched, but at the leg the weld puddle is mixing the weld filler metal and the lower strength base metal, in exactly what proportions, you don’t know. So, the shear stress should be based on the lower base metal shear strength. At the throat, you can be reasonably confident that the allowable weld shear stress is that of the filler metal. With your problem, LRFD and ASD the way they have it screwed around today, to match LRFD thinking, there meaning and results are kinda suspect. At least you really have to understand all the implications of this design thought process. Load factors, resistance factors, etc. are in place to keep yielding within limits under normal loading, service loads. In your case, you have a failure mechanism once there is any significant yielding, because there is no redundancy in the system or at the/your detail. In your case, significant yielding means strain and extension without much added load, whereas in the normal structural situations/details you can tolerate some yielding (start of hinge formation, etc.) because some distribution and added load cap’y. exists before a failure mechanism forms. Your details and design are much more dependant upon nice clean load paths and quality welding and detailing so as to minimize/eliminate any weld defects or stress raisers which might lead to sudden crack initiation/failure. If my details and welding are good and clean, I will tolerate a little confined yielding, knowing that there will be some internal stress redistribution and the stress/strain can’t really go anyplace, it is confined/controlled by surrounding material volume. You’ll see these high stress areas, reentrant corners, triaxial stress regions, stress raisers, etc. if you try to analyze your details with a FEA program.
http://www.lincolnelectric.com/en-us/support/weldi...
https://app.aws.org/wj/supplement/WJ_1997_06_s233....
