problems with Product Template Studio (PTS) in NX11
Hi All,
I started this topic because I have some problems with the product template studio (PTS) in NX11 while I didn't face this problem in the PTS of NX10.
I was making a PTS using linked faces and linked datum coordinate systems as input. In the PTS I was able to select the linked faces (in the feature tab), however the linked CSYS was not found in the PTS environment. At the moment I circumvented this problem by using NX 10 first. So, I start making the PTS in NX 10 and include the linked CSYS. Thereafter, I open the PTS in NX 11 and the CSYS is still linked in the PTS. However, when I want to link another CSYS in NX 11 directly this is still not possible. Is this a bug or do I overlook something?
Additionally I face a problem with linked sketches, when I re-use my PTS I get the internal error : memory access violation. I thought this was strange because if I just copy paste the PTS part and manually relink the sketch then it is working just fine. When I look more thoroughly to the PTS then I discover it doesn't recognize the sketch as a wave geometry link but just as a sketch (while the linked face is indeed recognized as a wave geomtery thus working properly)
Somebody here having similar problems or even better some thoughts about solving it :)
RE: problems with Product Template Studio (PTS) in NX11
Be sure to Install NX11.0.1 MP01 !!!
Didier Psaltopoulos
http://www.psi-cad.fr
