I want to manufacture ASTM 860 GR W
I want to manufacture ASTM 860 GR WPHY 60 fittings. What ASTM pipe grade should be ordered as starting material?
RE: I want to manufacture ASTM 860 GR W
Per ASTM A860 Wrought High-Strength Ferritic Steel Butt-Welding Fittings, Standard Specification ...
1. Scope*
1.1 This specification covers wrought high-strength ferritic
steel butt-welding fittings of seamless and electric fusion-
welded construction covered by the latest revisions of ASME
B16.9 and MSS-SP-75. Butt-welding fittings differing from
these ASME and MSS standards shall be furnished in accordance
with Supplementary Requirement S58 of Specification
A960/A960M. These fittings are for use in high-pressure gas
and oil transmission and distribution systems.
ASME B16.9 Factory-Made Wrought Butt-welding Fittings
MSS SP-75 High-Strength, Wrought, Butt-Welding Fittings
ASTM A960 Common Requirements for Wrought Steel Piping Fittings, Standard Specification for
Regards, Wil Taylor
o Trust - But Verify!
As I stated, a good starting material is API 5L Grade X60, which meets A 860 chemical composition and strength requirements to manufacture fittings. There are others starting materials as well.
Steve Jones
Corrosion Management Consultant
http://www.linkedin.com/pub/8/83b/b04
All answers are personal opinions only and are in no way connected with any employer.
