Plate Heat Exchanger Design
Good Morning.
How to calculate the required thickness of heat transfer plates in Plate Heat Exchangers (PHE) as per Section VIII Division 1?
I can see only in API 662 that minimum thickness for plate elements shall be 0.5 mm. UG-16 excludes PHE from minimum thickness requirements.
Is it a U-2 (g) case?
Javed Nasir
Inspection Engineer
Technip-France Abu Dhabi
RE: Plate Heat Exchanger Design
I came to know from some friends that Edition 2017 of ASME Section VIII-1 will bring Appendix XX dedicated for PHE, is it correct? any comment?
Secondly any idea, how to establish MAWP for fully brazed or fully welded plate packs
Javed Nasir
Inspection Engineer
