flow control philisophy
Hi, i am curious to know why some seal gas flow control design have an orifice in parallel to the valve ?
RE: flow control philisophy
Given the valve is a FO design, indicates that excess flow or pressure is not a big issue, but low flow / pressure in.
I've seen this also done by mechanically limiting the control valve to a certain limit of closure.
Downside is it will not seal shut, but neither did the orifice.
Best regards, Morten
When the control valve is FC, the bypass RO may enable seal gas flow at a controlled rate for some time when there is a general plant power failure and the instrument air supply pressure has dropped off rapidly. When seal gas flow / pressure has also dropped off, the compressor should be auto depressured ( if it hasnt already by this time).
You could probably achieve the same result if you had the dPCV fitted with a min stop (either mechanical min stop or soft stop in DCS may do).
