Using two different USDFLD subroutines in a problem
Dear friends,
Could anyone share any information about using two different usdfld subroutines (each for one material) at the same time in an analysis? Is there a specific format for using them in the same file? I searched and found a few formats but it seems they don't work for me.
Thanks for you kind attentions
RE: Using two different USDFLD subroutines in a problem
You must not use more than one USDFLD subroutine.
You can test your material name with CMNAME variable to do different operation for each material in your model.
See following thread for more info:
http://www.eng-tips.com/viewthread.cfm?qid=314887
Bartosz
VIM filetype plugin for Abaqus
https://github.com/gradzikb/vim-abaqus
Best regards,
Amin
