IS PWHT required for 26mm plate as per ASME SEC VIII DIV ?
We have 26mm shell plate for the vessel. Do we need PWHT as per the ASME SEC VIII Code ?
RE: IS PWHT required for 26mm plate as per ASME SEC VIII DIV ?
Material? Which of the 3 divisions of Section VIII are you referring to?
