Piping Isometrics
Piping Isometrics
I am new to Microstation j716 and trying to develop piping isometrics.
I am able to draw isometric lines easily per the Isometric settings on microstation. However, How do I insert valves in the proper orientation?
If the x-axis runs horizontally on my screen, how do I rotate with respect to the x- axis? Currently, I only able to rotate objects with respect to the Z-axis.
RE: Piping Isometrics
In short, I would recommend working in 3-d for that, or using some outboard software and previously suggested.
Robert Weber, EI
Maurer-Stutz, Inc
www.maurerstutzinc.com
"I am satisfied that your answer is correct. I am not, however, satisfied that your answer is right."
Are you using "ACCUDRAW"?
'Cause if you are ...then go into your "ISO VIEW" window and just rotate using "2 points".
type "T" for top spin which is your "Z" axis
type "S" for side spin which is your "X" or "Y" axis
type "F" for front spin which is your "X" or "Y" axis
One of those should do the trick for ya'
Let me know if that accomplishes what you need.
Later.
Rich
